Thank you
Then the connection would be as follows
From the source I carry positive and negative access control.
from the source I carry the electrical lock positive and negative to the COM terminal, and from the terminal NOT a cable to the lock.
I don't know if I have to pass the positive or the negative through the relay, or if it is indistinct.
Thank you
