Household Electricity
Electric connection
Bruce Wildor
hace 6 años
hace 6 años
Hi. I have to do an installation of a led and two shots in a barbecue of a house. The distance from the house to quincho is 20 meters. I am going to use underground cable, my question is: will it be good 4 mm Because of the voltage drop? Or with 2.5 mm would it be fine? Thank you.
hace 6 años
hace 6 años
Hi. In these cases and as you do not know if at any time they will place a socket and plug a welding machine even if it is small in this line, place 4 mm² without problems. Regards
elektomaq
elektomaq
62.202
hace 6 años
I agree
Bruce Wildor
hace 6 años
Thanks, I'm going to handle with 4 mm as I planned then.
