As to add to the above, a correct thermomagnetic protection must be ensured to the device, for this you can opt for the following options:
1) that the upstream thermal is ≤ to the nominal of the device
2) that the sum of the downstream thermal be ≤ to the nominal of the device
In other words, the same criteria are used as with differentials
