Household Electricity
Work budget
Luis Cabj
hace 6 años
hace 6 años
Good evening I wanted to make an inquiry for an electrical installation is for the budget since the client claims that it is excessive It is a piece of 4 x 2 and wants me to put 4 shots I have to chop and put the curling and speed everything and of course make the connections I pass 1500 and I claim that it is very expensive you who say? Thanks in advance
michito120162
hace 6 años
Offer to do it with cable channel and external boxes, for economy, aesthetics and speed. In addition, to channel can avoid painting part or all of the wall.
nastor
nastor
17.232
hace 6 años
hace 6 años
Hello If the work is well done and consists of canaletear, bulge 4 boxes and several meters of pipes, then wire, place the keys and everything is working, you have to have a labor cost of 450 pesos for each mouth, that is a minimum of 1800 pesos; This value can rise much more. Wide, it considers that 300 pesos are charged for each box + 3 meters of pipes placed in the wall (only work of grinding).
Luis Cabj
hace 6 años
Thanks and if I have to chop and hurry everything
elektomaq
elektomaq
62.202
hace 6 años
hace 6 años
Hello Full mouth finished under standards, $ 800 is charged (Buenos Aires) 4 boxes of power outlet are 4 mouths at 800 each are $ 3200 If you spent 1500 you gave him the job and if he says it is very expensive for him to do it ... Let's see how it works
Carlos Padilla
hace 6 años
You're giving him the job. At least you have to charge $ 3,500. but mark the wall where the pipe and the cjas goes and that the chopped!
elektomaq
elektomaq
62.202
hace 6 años
What is the comment Carlos? It has been a year since we participated in this topic
ger27
ger27
15
hace 6 años
hace 6 años
Hello, it all depends. I share what the colleagues say. Here in the south there is 600 the mouth. It depends as I told you if it works for you or not. If it is the first time you work and want to earn it or not, for me that price is well .. I am just opening my account x and even if it was 1200 I would do it xq I repeat it is in a day as much and the daily wage today is not paid well, but good luck is at your discretion
nastor
nastor
17.232
hace 6 años
Hi Ger
Everywhere in the country the mouth comes out, pesos more, pesos less, the same, that would be around without the last economic breakdowns something of 750 to 900 pesos; from there more or less depending on the quality of work (electrician), the quality of the work, and type of work. Of course, the same is not true in Puerto Madero, which is in the middle of the pampas, but at the same time it will not vary by more than 20%. In cases of repairs the standards are different, and the prices are more suited to the times and circumstances; I agree with you, it is done in 8 hours and you can charge less if they are your first jobs.
nastor
nastor
17.232
hace 6 años
Personally I would not charge less than 2000 pesos, but not more than 2600 pesos.
Luis Cabj
hace 6 años
If that is obvious but I wanted to make sure first.
I had a better idea of what the work was worth and I charged less
Only that it made me angry because I claim that the work was very expensive
nastor
nastor
17.232
hace 6 años
There is a lot of competition, he sees you in need and is abused.
ger27
ger27
15
hace 6 años
thanks nastor. and Luis always people are going to complain. If you take a long time they say you don't know and if you do it fast they say that it is expensive
Luis Cabj
hace 6 años
That is obvious you have to know how to take it depending on the kind of customer you touch. Greetings and thanks colleagues
elektomaq
elektomaq
62.202
hace 6 años
Everyone will know ... but at 1200 I don't even take half a day. You will always find clients who tell you that it is expensive and if instead of 1200 you ask 700 they also tell you that it is expensive, because they are mice with pardon of the animal. I agree that if the job is worth 3200 copper something less to be more competitive and secure the job, but not charge a third of what it is worth
elektomaq
elektomaq
62.202
hace 6 años
I clarify something ... an independent electrician with 1200 pesos per day does not live, eat if ... but can not keep his working capital, let alone grow, and it is important just to start growing
elektomaq
elektomaq
62.202
hace 6 años
Well-charged work begins to be expensive when others charge anything and as they charge anything, they do anything, then you start to find metal boxes without their earth, pipes without connectors, crooked boxes, sockets melted by loose connections, cables of smaller section , you take poorly polarized etc etc etc, why? Because what counts is to make it fast and to stay as it is
elektomaq
elektomaq
62.202
hace 6 años
I don't say it because of what was said here, I say it because it's what I see on the street
You have to charge what the work is worth but you have to work well ... they recommend them for good jobs, not for cheap
elektomaq
elektomaq
62.202
hace 6 años
On the other hand they say 1200 1500 in a dua is good silver, an air installer charges 3000 per installation, 2 hours of labor and the same customer who said 1500 is expensive for a full day of an electrician, gladly pays for the installation of the air, in that sense that guild is much more organized than the electric one, here as most do not value their position
elektomaq
elektomaq
62.202
hace 6 años
Anyway ... think about it
nastor
nastor
17.232
hace 6 años
It is not the same competition in the case of the installers of Aires, in electricity they go to work without knowing and compete unevenly, the light bulb turns on; then with the servise the question is to work every day and make a daily average of 1600 to 1800 pesos, so you arrive on Saturday with eight lucas, sometimes more sometimes less; and of course you make customers but you can't kill them if you want to be called and recommended.
nastor
nastor
17.232
hace 6 años
Another very different thing is a high-level works, where you can assert yourself if you have that, there if you put your numbers, and low if you need to. Today the times are difficult, and it is very personal how each one acts.
elektomaq
elektomaq
62.202
hace 6 años
But the issue is that you never have 1600 1800 every day
elektomaq
elektomaq
62.202
hace 6 años
The comparison of the air was by what the client is willing to pay. You would be surprised but the air installers are not technical at all and generally learn or take a course of 30 hours or pure courage by reading the installation manual
elektomaq
elektomaq
62.202
hace 6 años
A level 3 electrician installer studied a whole year 12 hours per week
An air installer has no idea what that means
nastor
nastor
17.232
hace 6 años
Anyway, the air conditioning work was finished, as the work of the workers' small house was finished. That disappears from the market, few airs and many installers.
elektomaq
elektomaq
62.202
hace 6 años
To reach high-level works you have to grow and much professionally and in capital. You need people in charge and charging that I can guarantee you don't arrive
nastor
nastor
17.232
hace 6 años
I have quit a lot of small work or repair, luckily I have some great works, but I never stop going if they call me, and I combine one thing with the other. The half day I get repaired, I usually do 900 pesos, if it is a minimum work of one hour, you do 400 pesos, but you are supposed to continue with something else. The problem is when the works do not appear, but you cannot try to save a week by charging what you did in a day. It is an advantage when you are a veteran and they know you, you reap what you have sown, but if you start killing, in the same way they call you "carero" and it is over
nastor
nastor
17.232
hace 6 años
elektomaq, I have very large works (three 280m-300m-450m), and I usually work alone. I understand that in BsAs it is different, but I had an employee for a couple of months in November and last December, then I hired junior electricians. But I don't kill the one who always gave me work, it's my style, there are others who work differently.
elektomaq
elektomaq
62.202
hace 6 años
No ... I do not talk about charging the week for a half-day job, that never ... I just talk about charging what the job is worth and a little less, just as you said you would charge that job between 2000 and 2600 which seems correct to me but it is not a matter of charging what the client wants,
elektomaq
elektomaq
62.202
hace 6 años
In bs as that work I charge 2800 and if he grabs me in a time of skinny cow I lower it to 2200 but not less. Lastly, I prefer to pay two or three times, but there I already charge him no mdnus of 3000
Carlos Padilla
hace 6 años
hace 6 años
I always say: The painter for painting one or two pieces in one day charges you $ 4,000, and you see the work with the naked eye, but an electrician wants to charge you $ 2000 (half) for a day's work and they seem like an eager. (because the work is not seen) they ask you to put a lamp in the shed at the bottom and you denied all day with the pipes covered and everything that drags you and that the client does not see it, just says; for putting a light bulb wants to charge me so much ???? Today, the official wage and an assistant round in the $ 2,000 daily. (and if you pass them through a wired mouth they get double
nastor
nastor
17.232
hace 6 años
Hi Carlos, it's like you say, on a good day an electrician can get some 2000 pesos in service if he works all day, it's not common, it doesn't happen every day, at least outside the big megacities, but in jobs of new building works is different, the prices are different, and quietly 50 to 80% more than those 2000 pesos that you have so much to repair are removed.
When you say officer and assistant, you talk about hired people, and those people are electrician or not, they don't reach that amount in four days.
Luis Cabj
hace 6 años
In the end people know what happened. The client called me again to ask me to add it apparently another wanted to spend more expensive. And that they believe the installation was already done, he told me that he did it but that it didn't work that he skipped the thermals every time he connected something. And mmmmm is a horror what I found all unipolar cables section 1.5 mm in sockets and without pulling FATAL ERROR also in the light key instead of putting the lamp phase put the installation short
Tube to charge you more than it had to be for everything I found
Carlos Padilla
hace 6 años
NASTOR: how are you ??? How much do you charge the day of work with an assistant? (because many times you need a hand) and how much do you charge for a repair that is 2 hours or day? I consult you to be aware of the prices, and not kill the client or give away my work
Carlos Padilla
hace 6 años
Luis Cabj: That always happens !!!! And that's where you have double work and a secure customer !!! It doesn't matter if repair takes half a day, there you charge it triple. And I told you the classic phrase: I DO NOT CHARGE YOU FOR WHAT I DID, I CHARGE YOU FOR KNOWING HOW IT IS DONE AND FOR KNOWING WHAT SCREW OR CABLE I HAVE TO CONNECT !!!!
nastor
nastor
17.232
hace 6 años
Hello Carlos, I will pass you as I handle myself, which does not mean that it is the right thing, unless the rest do it that way. I am from a small city of Santa Fe, this is not valid for Rosario center, Córdoba center or Buenos Aires center or another place where you work being practically anonymous; I manage with clients, people that I have harvested through many years, and it is necessary to differentiate the home service to individuals, in which I charge a value, and the works of work, where the price is another and there is much more money left. I don't work with an assistant, at most I hire a junior electrician
nastor
nastor
17.232
hace 6 años
I clarify, I never work for time, that's my way of calculating certain repair jobs. If it is in a new work, I calculate something of 850 pesos the mouth, when it is a simple refinement or small department, the number is reduced, but the time of work also. The minimum for that item is 1000 pesos per half day, it can reach 1500 pesos.
Change if it is service, the minimum work, that is an hour or less, something of 400 pesos, the pair of prayers something of 600 pesos, the half day 1000/1200 pesos depends on the repair work, the day of 1800 to 2000 pesos .
nastor
nastor
17.232
hace 6 años
If it is a grounding fault (leakage) or short circuit something I do in a couple of hours, about 1000 pesos or 500 minimum, this guy no longer gives it away, before he charged like any job; if it is an emergency, more; If it rains more, if it is Sunday a little more. Today is getting hard, they call little for repairs, but luckily I have works for the rest of the year. But the slogan is not to lose customers, that is, of every 10 customers, eight should call you again for work and price compliance. Subjects industries very little, almost nothing in recent years; Something from the municipality.
nastor
nastor
17.232
hace 6 años
There are days when things get difficult, so there is progress in the work, otherwise, that day you go back. Anyway, there are times that you make 500 pesos in the middle of the day and you deny a lot for the difficulties, it is not that you put a number and it leaves.
Carlos Padilla
hace 6 años
It's perfect, the number is reasonable, it's perfect. because in our field you cannot specify the time according to the fault that exists, and more if you have problems with a circuit breaker that jumps and you have to check word of mouth it is difficult to calculate or pass a price, you can find it in 10 minutes or half day, a big hug !!!
