Household Electricity
Budget connection 14 led reflectors
osvaldoivo
hace 6 años
hace 6 años
Hello how are you. I would like to know how much the connection of 14 50w led reflectors is charged. The total wiring is 100mts. The pipes and mouths are already walled. It is only wiring and connection of new devices. I am from Argentina. Thank you
elektomaq
elektomaq
62.202
hace 6 años
How high are they?
Are they on a wall or on columns?
What means do you have to upload?
osvaldoivo
hace 6 años
Established at 2 meters
elektomaq
elektomaq
62.202
hace 6 años
hace 6 años
Very low height for reflectors but good ..... You have wiring of 14 mouths plus installation and connection 5600 pesos, hence the discount you consider, I would personally charge it between 3500 and 4000 since there is no need for stairs or anything, it comes out fast
osvaldoivo
hace 6 años
Thank you very much I calculated 4500. It is for a garage x that the height. I'm new to the page, the answer helped me a lot
osvaldoivo
hace 6 años
I don't know if it's okay how to put the score. I would put 10 but I can't
elektomaq
elektomaq
62.202
hace 6 años
Yes. 4500 is fine
The score is fine, thanks
