Thanks for your answer. The work must be done in a private neighborhood, this person bought the kalop keys, my doubt is the price, I was planning to charge $ 100 per key or mouth (which are not more than 15) you who think the price is right? Is it expensive or cheap? The owners are a young couple and they only change it because they are yellowish.
It's my first job charging, I do this job because he doesn't find his electrician and they don't want to put anyone else in the house.
I would appreciate your response again
The price to collect is 150 pesos of labor, you can lower a little, but if it is in a private neighborhood (Yerba Buena?) Do not do it; You will surely have points and shots, single shots and double shots. Keep in mind that you should check splices, the good thing that if it is the same brand you change, hardly deny with the racks.
It carries headlight, male headband and screws 5/32 "milled head.
I forgot to tell you that it has double Thomas, dots, combo and TV connectors; With the theme of tools I was doing little by little, since I do a lot of work for family members on the weekends and this is the first one that I received, I have a flashlight, cutting pliers and force (insulated) screwdrivers among other tools and several screws .
I don't know if you will be a sorcerer, but it is right in Yerba Buena to work hahahaha.
Hahaha, no, it's the little residential Tucuman I know; If you are not asked for a budget, you have to charge it as a good day, since in six hours you can do it, that is 2000/2400 pesos average. If you put half a day, you can lower it a bit, so they are happy and the desire of customers, apart they make you advertise in a residential that not everyone enters.
