Being a three-phase service, using it as three monophasics separately, the intention of balancing the consumption in the phases, is a fallacy, because unless you use all the power installed simultaneously, you will have one charged, when you use oven or washing machine , and depending on the simultaneity, another when you turn on some lights, another when you use the floor polisher or vacuum cleaner, etc. therefore, I don't see why to spend the effort and money on that. with a neutral of 4 or 6 mm2. each line with 4 mm2, and the lights with 1.5 mm2, using led lamps or low consumption. luck
Thank you, the issue of leaving a single 4mm cable. for the whole kitchen it was for the theme of the space in the pipe, which is already fair and still lacks the neutral of 4 mm. That is why I had thought to take out the 2.5 mm phase and neutral, add the 4 mm neutral and connect all the sockets with that of 4.
Thank you very much Nastor! I will see to do that. But the other possibility that I thought today is to leave the 4 mm circuit for the oven, and a circuit with 2.5 mm cables shared between sockets and luminaire, but what you tell me is convenient.
