Household Electricity
Hi, I wanted to know what a three-phase smart protector is for
inespinguinos
hace 6 años
hace 6 años
Hi, I have problems with power outages and I wanted to know what it was and what it was for a three-phase smart protector and if it serves to protect the electrical appliances in the house. My house is all electric, even the heating is by electric cables on the floor. Thank you
Jose A. Martinez
hace 6 años
Hi, a three-phase smart protector, it is a circuit that constantly monitors the power supply from where it is connected, if a phase is missing or the phase rotation changes, the voltage drops in any of the phases or rises, in any of these cases disconnects the circuit downstream of it. but it would be useful only if the power of your house were three-phase and for the voltage that is designed, if not, you should look for a single-phase one.
inespinguinos
hace 6 años
If my house has three-phase. So I need one That is three-phase, right? Is there for different consumptions? Could you recommend a brand that is good? Thank you!
nastor
nastor
17.232
hace 6 años
hace 6 años
Hello One reflection, there are no intelligent protectors and turnip protectors, that is rather marketing; It refers to an all-in-one protector, usually high-low voltage with some aggregates, can be thermal included, lack of phase, ... with some type of alarm, or light indication. In short, nothing out of the ordinary in multifunction protectors. Regards
inespinguinos
hace 6 años
Thank you!
elektomaq
elektomaq
62.202
hace 6 años
hace 6 años
Hello keep in mind that while having three-phase, the three-phase protector serves you, this type of protector is more suitable only for three-phase loads In your case, it is not recommended, unless you have three-phase motors which if you can protect separately from the rest For all the rest of the house, where the loads were single-phase, use single-phase protectors The difference is that if you have a problem in one phase, the intelligent three-phase protector will cut off the entire supply, while three single-phase, only one will act leaving the other two active since these two have no problem and can continue to operate in single-phase circuits. Regards
inespinguinos
hace 6 años
Thank you!
inespinguinos
hace 6 años
I mean, what I want is that when the power goes out, a lot or low electricity comes, the electrical appliances in the house are not damaged .... Do I have to put on a smart protector or something else?
Excuse me but I am not very knowledgeable in the subject and as what they offer me is so expensive (intelligent three-phase protector) I would like to be sure. Thank you!
elektomaq
elektomaq
62.202
hace 6 años
Do you have three phase artifacts or is everything single phase?
inespinguinos
hace 6 años
The house is three-phase but the circuits are monophasic .....
elektomaq
elektomaq
62.202
hace 6 años
Then you should separate the protections
Three single-phase voltage protectors, not necessarily intelligent and according to the consumption per line, adding a contactor to each one, in this way, any event that affects a line, will not affect the remaining two
