Greetings nastor, greetings servimat1
Greetings nachoteloco ,, the electronic circuit works less than 24 volts and the water contains impurities and sediments that will be fixed in electrodes and will cause false
Yes, please support Servimat! I saw some diagrams with a contactor, a 24v coil and even a manual and automatic selector key. I will choose to arm it with electric floats ...
First servimat1! If I wanted to add a key to use it manually or automatically, where should I place it? In case I have a problem and I must turn it on manually.
But what a service !!! You want is you have it! Genioooo. I already save the image and I will find out everything costs.
Many thanks!
