Household Electricity
Suggestions for supply on the ground floor and upstairs
Antonio Emprendimiento
hace 6 años
hace 6 años
Hello good people! I commented that recently I received a home electrician and I need a suggestion. I have a ground floor already with supply and the owner has just finished a high floor where he has 2 bedrooms and a bathroom but had no supply in PA. My question is: how would it be more convenient for me to supply up? I thought about putting a distribution terminal in PB and from there to distribute and it would be like that. Circuit breaker (ID) followed by general TM plus the distribution for the TM of each circuit. after the distributor I leave Asia a General TM that would be for the top floor and there to put the TM for lighting and shots. If they correct me and give me a hand it would be very important to me! Thanks and sorry if I wrote too much. Hug
danny_rosariorc
hace 6 años
hace 6 años
If you want to make a sectional above. General board ID - TM gral. ---- there you section up and down and your secondary circuits. Although you can do everything on the general board, separating the circuits.
danny_rosariorc
hace 6 años
Keep in mind the future installation of refrigeration equipment.
hace 6 años
Ok, thanks for taking your time Danny.
Hug
elektomaq
elektomaq
62.202
hace 6 años
hace 6 años
Hello each floor must have its own board The power supply of that board can leave from the main board (TP), from a general sectional board (TSG) or from the sectional board in use on the ground floor (TS), in which case you must evaluate the sectional circuit that feeds the TS since adding the upper floor can be subdimensioned In all cases, the upper floor sectional circuit must start with a specific thermomagnetic
hace 6 años
Elektomaq thanks for the help. I tell you that 6 mm cable arrives in the house which would not be complicated to bring the supply up and would not be subdivided. Thank you very much for the contribution! Hug
