Household Electricity
Type of electrical cable to use
Jonito Vera
hace 6 años
hace 6 años
Hi . I have to put 4 lanterns to illuminate the patio. And that all turn on continuously with a photocell. I wanted to know if it is okay to use a 2x2.5 mm workshop cable or is it very thick?! I would appreciate any help! Greetings Jonatan
elektomaq
elektomaq
62.202
hace 6 años
hace 6 años
Hello 2.50 mm² is perfect What is wrong is the type of cable, that cable should not be used for fixed installations underground cable is recommended. If possible with xlpe insulation Do not forget the protective conductor (ground) regards
