Household Electricity
Connection 3 LED reflectors 20W. When the Last DESTELLA is turned off
pepeh009
hace 6 años
hace 6 años
Hello how are you. My question is the following. Perform the installation of 3 20 W LED Reflectors, Akai Energy Brand. Perform as follows. Use a 3x1 TPR cable, to go all the way around the property that are approximately 37 to 40 meters. For one of the cables (Celeste) I carry what would be the Neutral. On the other (Brown) I carry the Vivo, to be able to also feed 3 outlets that are in the line and finally by the last (Green) I carry the current of the Reflectors, which goes to a single point cut-off key to turn them off and turn them on. The system works seemingly well ... The sockets have power, the reflectors turn on and pay perfectly. But ... here is the inconvenience that I can't solve. I turn off the reflectors, and the last of the line, every 30 seconds MAKES A FLASH, and so on constantly. I thought I was wrong at the time of assembling the key, and that I was cutting the Neutral instead of the Live one, Well NO… a the key normally arrives from the live one. Then disconnect the last reflector because I thought it might have problems and what happened, the other two began to flash every 30 seconds. I put the Pager on the line that goes to the reflectors with the key as if they were off , and the following happens: the light of the pager begins to turn on little by little, and more and more, until the reflector flashes and the light of the pager goes out. I do not understand where I am arming the line badly! I burn my head.Thanks in advance for the help.
Ricardo Ab.
Ricardo Ab.
5.181
hace 6 años
You are missing a cable ... earth. That installation can lead to dangerous errors. Both the shots and the reflectors MUST HAVE PHYSICAL EARTH. Regards
nastor
nastor
17.232
hace 6 años
hace 6 años
Hello The problem is that there is capacitive coupling (badly called induction) of the live cable with the return of the reflectors, the coupling is greater the closer the live one is to the return, the longer the distance they go together, and the further the distance is. live ground wire (not forgetting that you have a round wire and no grounding wire). The solution in putting in the reflectors that make problem a capacitor between the terminals of this one, that capacitor you get it in the houses of electricity like "inhibitor of flash". And of course, as Ricardo (greetings) says, connecting a grounding cable to the reflector is really important to avoid possible inconveniences.
Ricardo Ab.
Ricardo Ab.
5.181
hace 6 años
Greetings "REFLECTORS AND TAKES"
pepeh009
hace 6 años
Perfect ... Solved with the Capacitor as explained in the Plan.
nastor
nastor
17.232
hace 6 años
I'm glad.
