Household Electricity
Public lighting
Tesla1998
hace 6 años
hace 6 años
[i] Hello, I hope you are well, you just asked me to change a ballast for a sodium lamp, the problem is that you bought one of 150w and the lamp is 250w. I understand that it is not good for the useful life of the ballast, but apparently the person who bought it ran out of money to buy the corresponding lamp and prefers not to change it. My question is: Is it convenient to install it as it is? Could it bring inconvenience in the short term? Thank you very much in advance. [/I]
Edurau
Edurau
835
hace 6 años
A "ballast" used for electrical elements, "discharge lamps" in this case, is a current limiter, because in this type of lamps, which work by electric crackling between metallic particles in gaseous suspension, the amperage tends to become infinite with the heating, hence if the device accepts 150 w, limits the current for that value, therefore, 250 watts, requires more current, that that device will not deliver it to you, it will be useless. I hope I was clear. luck
Edurau
Edurau
835
hace 6 años
nastor
nastor
17.232
hace 6 años
hace 6 años
Hello The question is inadmissible, you answered yourself, you cannot put together a team mixing elements of different power . Regards
hace 6 años
hace 6 años
Hi. The issue is that you should see if you turn on the lamp. In doing so, soon the ballast will overheat. Keep in mind that you are taking 100W more from its design. Regards
