Household Electricity
BUL-903EDFP transistor replacement is NPN
bernardo justiniani
hace 6 años
hace 6 años
if some of the large community of YOREPARO knows what the replacement of the NPN BUL-903EDFP transistor will be, which works with an electronic ballast co and I don't get it in Caracas, Venezuela
nastor
nastor
17.232
hace 6 años
hace 6 años
Hello If you want to do it that way, and you are sure it is the transistor, simply look in a list of equivalences. Transistor replacement finder - click here This is the search engine and the alternatives these are the 100% the same This is the list of transistors of similar characteristics
bernardo justiniani
hace 6 años
Thanks, where can I find that list?
nastor
nastor
17.232
hace 6 años
There you have your replacement
