Household Electricity
Problem with led lamps
Pipo1978
Pipo1978
115
hace 6 años
hace 6 años
Hello, a few months ago I am looking at my house that when turning off the LED lights, they are blinking as if they wanted to turn on, in the laundry I put a led reflector and it is half lit and I have also noticed that they burn very easy. I am a refrigeration technician and I have some idea. But the truth has disoriented me. Will there be any return .. ?? could someone give me a hand with this .. ?? I do not know if it has to do, but I have seen that in the keys or keys there is a witness or resistance light that does not work at all Regards From already thank you very much
tecnico54
tecnico54
22.006
hace 6 años
the keys have pilots or they are just simple
Pipo1978
Pipo1978
115
hace 6 años
Pilot will be the indicator light of the key .. ??
If so. Yes
tecnico54
tecnico54
22.006
hace 6 años
if the key has a warning light there is the problem
danny_rosariorc
hace 6 años
hace 6 años
Remove the "witnesses" many LED lamps do not support it as well as dimmer. In other occasions, having no witnesses or neons is known to put a relay on a lamp since the return absorbs current in the pipe. I have never needed it. Except in houses with Domotica
