hace 6 años
Hello
It is possible that the fault is due to reversed polarization. Remove all the lamps to cancel the return and there is no confusion and check that the phase reaches the switch, if so it is not necessary to invert anything
If the switch has a light indicator, that may be the other probable reason, in which case it must be removed
regards
