Corrections: I plan to place the same order of the photo wires, if you have any recommendations for this. I would appreciate it, because it is totally different from the single phase.
- The voltage in Peru is 220V
- I am not sure if the 3 wires that come from the general meter that is outside the house, are the 3 phase wires or 2 phase and 1 neutral.
- To change them I will wear insulating gloves and I will lower the general light key (the one in the meter outside the house) Is there still a risk? because they are two phases ..
Hello, the drivers are all 12 AWG except the 3 phases that come from the measurement are thicker I think number 10. Regarding the heater it seems that that 30A that says in the product is recommended. Get to change only the general key to one of 3x40A and the lighting to a 2x25A (the previous one of 40A I think it was too much for the consumption that there is) yet do not change the thermomag switch of the heater to one of 32A, since it is already It was night. On the circuit, yes, it is better that a three-phase specialist takes care of that (I just know something basic). Thank you for your input.
Yes, I made mistakes thinking I would have neutral, but no, all three wires are phase. I get to change them and it works normal, but yes, it is obvious that for the improvement or optimization or anti-failures of the whole board a specialist is commissioned, I only read of basic concepts on the internet, and even more that it is three-phase, it is something that I should have more preparation Thank you
Hello, thanks to those who took their time, and if the 3 wires are phases, there is no neutral and I got to change the general key and the lighting key that had 40A I put one of 25A. Regarding the heater key I will change it these days. Although I lowered the general key of the meter while I was touching the bare copper tip of one of the 3 phases and reinstated a slight current (I was wearing gloves), I put the wires in the same place. It is better for a remodeling of the entire circuit is commissioned by a three-phase specialist. Thank you all.
