Hi elektomaq. Thanks for your answer!
I thought that the PVC insulated cable was allowed, since here in the town almost all the connections are made like this, what I was not sure was the way of fixing.
Now knowing this, my intention is to do it in the way that corresponds to the preset that you mentioned to me.
What was not clear to me is how the prestressing is fixed to the exit pipe of the pillar and to the entrance of the domicile: 1. What do you mention how a tensioner would be a steel cable fixed between both points? 2. The preassembly as it is subject to the tensioner?
Regards!
Being only 6 meters there is no need for tensioner, you buy a pair of clamps for 2x6mm2 cable and a pair of hooks, clips or brackets for anchoring, fastened at both ends leaving the cable not too tight (make a slight rope )
As the cable is black you must identify both the phase and the neutral, which you can use brown and blue insulating tape respectively
Thank you very much, I will rely on all the information you gave me to perform this installation.
Regards!
Hello, my intention was not to go out through the same pipe, since in the pillar there are two pipes. One through which the presetting of the distributor enters, and another through which to exit to the sectional board.
In which I will use the preset suggested by elektomaq.
Thanks and regards!
