Household Electricity
Connect lamp with key
diego.q
hace 6 años
hace 6 años
Good evening, I'm trying to do something very simple like installing a light and a key for it .. I have both the phase and the neutral wires, the neutral goes straight to the lamp and the phase is the live pole goes to the key and then goes out of the key to the lamp ... in theory this would be fine but when the key The lamp is off, it still has light ... it is much dimmer than when I activate the key ... it is like a low voltage light, does anyone have any idea what I did wrong? I leave two images attached one corresponds to when the key is off and the other to when it is on. Of course I welcome your comments.
diego.q
hace 6 años
I already know where the hand is coming from .. the switch I am using has a small signaling light so I investigated this type of key let a little current pass for the pilot and this current is what makes the light turn on minimally led i have.
Now the question is how can I do it so that it does not turn on without having to replace with a common key, I really like this type of keys with pilot
hace 6 años
hace 6 años
Hi. If you use an LED lamp you will always have this problem. You would have to replace the key or see to place in parallel with the lamp a flash inhibitor of those used in energy saving lamps. Regards
diego.q
hace 6 años
The inhibitor works perfect ... how nice to learn :)
hace 6 años
Nice to help you and you have solved the problem. Regards
Nico4706
Nico4706
3.081
hace 6 años
The inhibitor is a 0.47 uF capacitor
