Hello, my query is about the following, I did the whole gas installation of the new house, the gas pipe surrounds the whole house through the patio, without stuffing it, only the wall was drilled in the places where the gas intakes are, which is in the kitchen, in the living room for a stove and in the laundry room for the hot water tank. There are already all the perforations covered with cement but in the living room I have doubts about the separation between gas and electricity.
The issue is that the electrical installation passes through the wall and above the gas stopcock and parallel to it. It is separated from the gas stopcock by about 5 or 10 cm. and it is only in the length of the stopcock, since the spout enters through the wall from the outside inwards and to the touch goes an elbow to the right, the stopcock and another elbow down so that the pipe continues closer from the floor to the stove.
Something like that
This is how it would look inside the living room. Where the green line is electricity and the red gas, and the red double line part is the stopcock. If it is understood, it is seen that the stopcock is closer to the cables, about 5 or 10 cm. and then the gas moves away and the rest of the pipe remains about 20 cm.
The electrical pipe is made with the corrugated plastic pipe and the cables are new, about 6 or 7 months ago it was completely new. The truth is that I was left with the doubt of whether some insulator or something was needed. Later the house will receive several reforms, but at least within one or two years. And I could use at that time to place something if necessary. I await your opinions.
Thank you.
