hace 6 años
Hello
First of all, make the corresponding claim to the electric service company, some answer must be given.
Once this is done, verify the following:
First you must make a survey of the area, your neighbors, especially those that are connected to your phase.
You should measure the voltage as close as possible to the meter, under different charging conditions.
You should make a survey of the cable sections that you have in the connection, from the meter to the property, in the laying of the internal circuits.
Only with these data, you can think about getting a voltage booster, in the event that the low voltage occurs throughout your area, and the cable sections are correct for the load you have installed.
Don't hurry, follow my advice.
Consult your doubts.
