Household Electricity
Trying to repair something cut the light.
Fer Rapino
hace 6 años
hace 6 años
Good community My query is the following: I wanted to know if there is any system I can do so that if I am repairing something and it comes in short, I will not cut the light. Since last night it was cut and the thermal did not jump, the pole fuse burned and had to come edesur to repair it. From already thank you very much
hace 6 años
hace 6 años
Hi. What current are the thermal ones that did not jump? However, if you want to minimize the power outages in the place you can put together a small board that you will plug into any outlet, which contains a differential and a thermal of 2 x 10 amps. In this way you will limit possible problems a bit. Another option is to use a serial connection for example with a disused iron or a large reflector. Before connecting any device under repair as a test you can connect it here first. If it is short nothing will happen. The reflector will turn on in full brightness or the plate will turn on but nothing will burn or any fuse or thermal will blow. Regards
Fer Rapino
hace 6 años
thank you very much
hace 6 años
Nice to help you. Regards
Ennio Montenegro.
hace 6 años
hace 6 años
You can use fuses or a thermomagnetic that feeds what you are repairing. Before feeding directly from the network, a lamp is usually put in series with what you are repairing. When the fuse blows from the pole and not the sectional thermomagnetic which must operate first and if it does not operate, the general thermomagnetic must operate. In your case, it is not fulfilled by having increased the capabilities of thermomagnetic. For the safety of the people who live there, you should have the installation checked.
Fer Rapino
hace 6 años
thank you very much for responding
