Household Electricity
repair USB WALL plug, Kalop brand
floidian
hace 6 años
hace 6 años
Hi, I have these plugs and some really are no longer after months. Bad treatment they did not have. I opened one and inside it doesn't seem burned. Attached real photo of the plug that I disassembled today. What could be happening? Can one component be repaired / replaced with another or liquid? They are cheap compared to other brands that come out twice or a little more than that, in Argentina at least. Thank you! Here is the image. https://drive.google.com/open?id=1MPjmK3fGskRLXTWIWJ_vX3Y-rrExCOnl
Forzos
Forzos
620
hace 6 años
hace 6 años
Maybe I was wrong but one of the coaches does not seem bloated? Personally if you need to charge the cell phone, there is no better than chargers like cell phones, they do not fail .. Eye Kalop is a very good brand in Argentina. Another recommendation is that you take it to the house where you bought it, it happened to me that they came failed and they changed it (they were not usb plug but if other electrical device)
hace 6 años
hace 6 años
Hi. The modules that we are now placing in a work are Teclastar and cost almost $ 1000 each. Are these cheaper? What if they mentioned to me in the house of electricity that they do not have much guarantee since with a blow of tension they burn. On the other side of the board are SMD components? Does everything look fairly correct? Regards
floidian
hace 6 años
Half of them were similar to other USB devices at the time a year ago. I guess today should be the same. Maybe for something they go out less. It is a good brand, it does not usually fail in what are sockets and keys, but good. Regards.
