Household Electricity
Automatic full tank scheme
el pampa
hace 6 años
hace 6 años
Hello, my situation is to get a good and complete scheme of automatic tank, consisting of a tank and contactors with a single pump that goes up. And also the recommended measure of the pipes. I'm an electrician but after studying I never did a job like that. Until now . Do you know any link that I can then make the corresponding budget? Or a list of materials. The client at this time, only uses a 1/2 hp pump that turns on and off manually, but increases the population of the house and never supplies, and the pipe that goes up to the tank is the same measure as the one that goes down should not the one that fills be larger in diameter? I hope I was clear , Thank you
elektomaq
elektomaq
62.202
hace 6 años
hace 6 años
Hello read the following manual of my authorship https://www.yoreparo.com/electricidad/electricidad-del-hogar/manuales/5765964/instalacion-electrica-de-bombas-para-elevar-agua Any questions consult regards
Bandurria
hace 6 años
excellent tutorial, I would only add that, if possible, since it is an installation with external life, it would be good to take the power without going through a differential switch, and place this on the pump board, so that, in case of leaks, Act crazy and don't leave the house without light.
elektomaq
elektomaq
62.202
hace 6 años
Thank you
ID can be placed. separated from the rest but could not be on the pump's dashboard
el pampa
hace 6 años
Good day, I took a look at it recently and that is what I totally needed thanks for sharing !!!
dataelectronica
hace 6 años
hace 6 años
Hello Goodnight . I answer the second question. The pipe that fills the tank is fine. Mostly the water inlet to the tank is average. At least where I live. And the output of the tank is greater to have greater pressure. Regards
el pampa
hace 6 años
Good, now that you say I remember seeing another customer doing maintenance that the exit, which only went to the hot water tank, was visibly larger in diameter. It is always good to ask if one does not know, and if not leave it to those trained in the subject.
Thank you very much for sharing !
