Household Electricity
ground wire splice
Franco Isa
hace 6 años
hace 6 años
Good, I have a doubt, I am doing the installation of the ground cable of my house that has two floors, I have a board for the first floor and a board on the second floor ... My question is if I can take a 10mm ground wire from the javelin to the first floor board, put a busbar for grounding and from there comes a 10mm wire that goes to the other board of the second floor and others for 2.5 ground wires that go to the sockets. place on the second floor board another busbar for its 2.5 earth wires that go to the sockets. Can you splice that way in the terminal? or how do I get 2 of the first and second floor from the main land. Thank you.
elektomaq
elektomaq
62.202
hace 6 años
As you have described, it's very good
Luck
hace 6 años
hace 6 años
Hi. There are no problems using a ground busbar or drilling a copper plate, threading and using screws with pressure washers. What must be guaranteed is the continuity of protection. Regards
tecnico54
tecnico54
22.006
hace 6 años
hace 6 años
This is exactly how you plan it
CAM
CAM
CAM
9
hace 6 años
hace 6 años
[b] hello ... in all cases always the splices and [/b[[/size[=18.2px[brtadaconecciones[/b[[size=140[[b] you make, They have to be well fixed and tight. Greetings. [/B]
