Sergio
You must inform if it is single-phase or three-phase and nominal voltage
Also distance to the main board
Very important if there is availability of supply because it is not occurred to someone to put a fryer of 10 kWh, I go and the method ... we must assess whether the present supply has the capacity to provide those 10 kWh without conditioning the other consumptions
Comment
Thanks for your help. From the fryer I only know that it consumes 10kw. For the answers and some calculations I made gives me 10mm2 cable, thermal for 45 amp. 5 meters from the board will be installed. I just need to know what size circuit breaker to place. I did not consult that.
