Household Electricity
New electrical installation
Marcelo Primiani
hace 6 años
hace 6 años
I have to install an 80 liter electric water heater and cooker with a Philco Phce051b oven. I have been told to put two thermal, one for each device. What cables do you recommend using? Someone suggested me 2.5 mm but I'm not sure. And one last. What is the use of identifying live and neutral for this connection? Thank you
rafaeldp
hace 6 años
hace 6 años
The first thing to take into account is the consumption of each equipment and what voltage they work on, having this you can select the conductor gauge and the breaker to use in each case, how much current does each equipment consume?
rafaeldp
hace 6 años
In the sheet that gives the manufacturer tells you what the equipment consumes with that current you multiply it by 1.2 and it gives you the thermal to use, if it does not give you a commercial value choose one above and as for the driver download a table of drivers awg and in this it tells you the current that is capable of supporting each conductor gauge and so depending on the consumption of the equipment you choose the cable
elektomaq
elektomaq
62.202
hace 6 años
The awg conductor table does not correspond to this case
rafaeldp
hace 6 años
Yes why not
elektomaq
elektomaq
62.202
hace 6 años
Because the consultant mentions 2.50 mm² cables which confirms that he does not live in an area where awg conductors are used
elektomaq
elektomaq
62.202
hace 6 años
hace 6 años
Hello the 80 l water tank 2.50 mm2 and 16A thermal the kitchen with oven (its power is 6 kWh), 6 mm2 cables and 32A thermal regards
Marcelo Primiani
hace 6 años
thank you!!!
