Household Electricity
COMBINED WRENCH
nesnq-ar
hace 6 años
hace 6 años
Can I use a combination wrench to make a simple connection? It's an old rack, I want to use this rack so I don't have to change everything, I have a key to this combined rack, I don't get simple keys to that rack. The connection I must make is a lamp with a key. Thanks for reading my problem ,,
Eduardo G. Gomez
hace 6 años
Yes ... The combined key has 3 points works with another of the same characteristics, you can use it as a common key, but explaining it is difficult ..
The important thing that you can ..
elektomaq
elektomaq
62.202
hace 6 años
hace 6 años
Hello Of course you can. Very important that one of the terminals you use is the one of the middle. The next terminal can be either side, one uses it and the other is free. If at any time it fails, you have the option of passing the cable from one side terminal to the other that was free and you will recover the switch (the central terminal is immovable) regards
nesnq-ar
hace 6 años
Great .. is the answer I expected .. thanks eleltomaq.
