Good afternoon,
In my home, inside the board, I have 1 thermal of 10A, with 1.5mm2 cable for lighting and then another thermal of 16A with 2.5mm2 cable for the sockets. Add a 25A circuit breaker.
My idea is to add a voltage protector since sometimes there are spikes and incidentally to visualize the current consumption. I was looking at a BAW brand, 32A, but unfortunately it does not fit me on the board, since it occupies the size of 3DIMM and I only have 4.5cm of space. I saw others that only occupy the space of 2 TOMZN or GRALF brand DIMMs. Can someone tell me if they know these brands and if they are recommended to install in my home?
I leave the links of the protectors I saw:
https://articulo.mercadolibre.com.ar/MLA-705025468-protector-tension-baw-monofasico-32a-din-digital-volt-amper-_JM?quantity=1 (BAW brand. Does not enter the board)
https://articulo.mercadolibre.com.ar/MLA-775523557-protector-de-tension-_JM?quantity=1 (TOMZN brand)
https://articulo.mercadolibre.com.ar/MLA-762407211-protector-de-tension-riel-din-ab63c-gralf-_JM?quantity=1 (GRALF brand)
From already thank you very much!
Regards, Luciano.
