Household Electricity
Low voltage
RUSO100271
hace 6 años
hace 6 años
Hello good morning guys, since a long time ago I am complaining to Edenor for low voltage, (160-195 volt). I'm afraid that something will burn me. My question is if there is an artifact that gives me 220 volts throughout the house. I understand that I need a voltage booster stabilizer, but I believe that I cut the electricity by high voltage. Is there one that does not cut? Thank you
Edurau
Edurau
835
hace 6 años
About four years ago, for almost two months we had voltages from 130 volts to 185, I took the trouble to take note of the voltage every hour, call Edenor claiming and noting the number, then send a letter with all the technical data , the N ° s. of claim and his answers to the Enre, after 6 months, he ordered Edenor to reimburse me in cash an amount of money and I deducted in the bills a large amount of money, in fact I did not pay more electricity for more than two years, and all clients served by the same transformer, continues
Edurau
Edurau
835
hace 6 años
continues, they are 125 will refund a good amount on their bills, never had problems, except in cases of general court, what happens is that you have to do well technically and properly presented. luck
hace 6 años
hace 6 años
Hi. You can place a stabilizer for the whole house. It must be at least 5 Kva. You would have to hire a licensed electrician to take a census of your consumption and install the appropriate power device. regards
