Household Electricity
Sodium light turns on and off by itself
paloncho
hace 6 años
hace 6 años
Hello, my question is the following, I have a sodium lamp placed in the back of the patio for some years, it is connected with its respective ballast and photocell, the problem is that now it started to fail, it goes off all of a sudden and goes back to it is not possible to change the color of the photocell, but I prefer to consult before replacing the photocell.
paloncho
hace 6 años
So what would you suggest to replace the sodium lamp, a mercury or a mixer?
Ennio Montenegro.
hace 6 años
hace 6 años
You have the photocell damaged and the lamp is depleted.
paloncho
hace 6 años
First thanks for your answer, you say that apart from the photocell the lamp is also exhausted, or I'm sure you decide to change the two?
Ennio Montenegro.
hace 6 años
Surely both are damaged. If only at night the lamp is flashing, it is only the lamp. And if the day and night is on without going out, it is photocell damage.
Ennio Montenegro.
hace 6 años
There is another connection failure, which is not lamp or photocell, in that if the phase cable is inverted with that of the light, the lamp will be on and off all the time.
If it worked normally for a long time, this fault is discarded.
paloncho
hace 6 años
So I definitely discard the ballast?
Edurau
Edurau
835
hace 6 años
Enio is right. both fail, you must change both but no longer sodium
