Household Electricity
how much to pay an assistant to cut a wall
nastor
nastor
17.232
hace 6 años
hace 6 años
Hello colleagues This is a consultation for colleagues in Argentina, I have a work in which there are many meters of wall and very few boxes (there are places with many curves and straight pulls). I'm going to hire a person just for that. The punctual consultation is how much can be paid to an assistant per meter of pipe suitable for 7/8 "pipes and sections of 1" maximum, is machine cut with grinder and disc on thick, part with vertical insulating layer, ; estimate by mouth is complex since the sections are variable but exceed 6 and 7 meters, on the other hand, there are curves and many boxes. I do not look for boards of guilds, but rather, direct experience in similar situations, to be able to have another point of view. All opinions are always valid, and I thank those who participate. regards
agustinp
agustinp
2.247
hace 6 años
hace 6 años
that colleague, I do not have much more idea than you of this subject but in this particular case in which you contract I think it is something more subjective than an average as is usually the tables If the helper is going to do everything but cabler that I suppose you will, you could say half each, but it would be generous if you see it from a different angle from mine I would think a little less than half, able to speak boludeces, but I guess it would be the right thing: he does the work, you grabbed him and you know ... I would say that you look at drawing a denominator, it is more complicated to get an exact number A hug
nastor
nastor
17.232
hace 6 años
I want it to just cut and break the common brick wall with thick applied, the boxes I put it, this guy is new (he says he's an electrician) and I have to try it, that's why the difficulty of calculating. If it were with box and pipe, I estimate $ 180 a mouth, but here I have very long pulls and I do not want to be unfair. That's why I'm not convinced calculate by mouth and take percentage.
It costs me to calculate how much to pay to third parties and not to nail me.
Thank you
agustinp
agustinp
2.247
hace 6 años
and, capable that you can apply what gustavo says, it is good the idea of ​​paying you per day as long as you control it
is complicated, yes, that's why I thought it would be better to take a percentage or a denominator
if it only goes to chop, capable that you can pay 2 out of 5 puts it, if you get 200 your mouth pay more or less 90 pesos to it. the truth or idea, for me you have to evaluate you, total if you do not accept the laburo to you do not fuck you so much, you can look for another. Unlike when you budget to a third party because it is not convenient to "lose" the job
elektomaq
elektomaq
62.202
hace 6 años
hace 6 años
Hello what I would do is calculate how long it would take me to do it. Suppose that calculation 4 days I add one more day for the doubts and I calculate for 5 days to the day, put 500 that seems to me a reasonable figure would be 2500 pesos. From there if you want to divide it by the amount of meters and / or mouths is your thing but I advise you to regulate the times since I calculate the machines will be yours and the type to take one day less, you bust them regards
nastor
nastor
17.232
hace 6 años
It is a good alternative you raise; the one that I trusted to do the draft and box placement I do not have it available, there I paid for box / mouth.
I had another alternative, and neither. So this I do not trust me to do more than the draft, over calculate it by mouth is complicated.
In the case that I require people, I complicate when it comes to paying.
Daa
Daa
Daa
7
hace 6 años
hace 6 años
Nastor, I recommend you to the one who is going to help you with life insurance, they are not expensive, the grinder is an excellent working tool, I got past when cutting concrete to lock. In addition to wearing protective eyeglasses, helmet, gloves, mute. I hope that is your help.
nastor
nastor
17.232
hace 6 años
Thanks, I always make sure when I contract someone to do that job.
hace 6 años
hace 6 años
Hi. Another option you have is to buy a wall scaffold. You can even make your draft and keep the machine. They come from a disc, two and with strawberries. the latter are very efficient and in common brick you make an estimate of 1 mt per minute (straight stretches and being comfortable) Regards
nastor
nastor
17.232
hace 6 años
I did not know that, I'm going to look; I hope it is not the old strawberry, it weighs a ton and there is no shoulder that holds (I have one that I did not use years ago, it was impossible to handle, less now).
Thank you.
ydd:alualo
ydd:alualo
2.071
hace 6 años
hace 6 años
Hello, nastor, friend, good subject yours, I have had it and I give you my way of seeing it. Here in Mexico, today, $ 500.00 MX is charged, the whole mouth, and of course there is inclined the 3 stages, placement of tubes and boxes, wiring and armed contacts and lights with dampers, apart from other issues of connection, load centers, special circuits and special equipment such as lamps, flying butts, air conditioners and others But in your consultation, I pay for the grooves, taking into account a comfortable installation, and it is estimated that there must be a mouth every 3 meters for contacts or appliques of combeniencia, and for that purpose I calculate that way the grooves, and pay $ 125.00Mx , for every 3 mts. of grooving, with poliducts and boxes placed without repellos. I hope it is clear, or something serves you, but if you g something, broad information, which I repeat is for personal use, and does not obey any table or tabulador, greetings to all. alualo.
nastor
nastor
17.232
hace 6 años
I appreciate the contribution, the calculation when it is box placement and pipe is here about the percentage that you say, a little less also, the problem that I have long stretches and it is only the grooving or draft of wall (without pipes); I do not dare to give that also the placement of boxes.
It is a work of more than 400 meters and if I mistake the person I put to work I will regret having to remove it, besides the problems. That's why I look for different points of view.
ydd:alualo
ydd:alualo
2.071
hace 6 años
I understand nastor, but listen, it's not about embedding the pipes or boxes, it's just about grooving and presenting the pipes or pipes that you're going to put there, they are only supported with gypsum points, and of course the grooving comprises up to the boxes, also presented and semi-attached with plaster, which would be the plastering and leveling as well as the critical points of curves or levels of boxes, as well as their finish, you see it, whether you make it bricklayer, or speak to the mason, who does the work, what I say is the payment of mt. of slotted or chopped, not another thing, what do you think?
nastor
nastor
17.232
hace 6 años
With the masons of the work I can not count, I tried and was not positive. That's why I take my people.
ydd:alualo
ydd:alualo
2.071
hace 6 años
Good 400 meters. is an important number, and if it is worth carrying your staff, just remember that by day you can not count on the progress of the work, by the builders, to put your staff in full gear, you would have to wait for it to be black work to start with yours, or you can not go according to the work, you have to hire by mt. linial, in my case is by mouth comprising 3 mt. of grooving, and of having more between one mouth and another, is always calculated equal, as if every 3 mts. A box will be placed even if it does not exist, greetings luck alualo.
