Household Electricity
Tube led
Discohe
hace 6 años
hace 6 años
How to install 2 T8 LED tubes with switch
hace 6 años
hace 6 años
Hi. Most LED tubes only need a voltage connection at their ends. What brand are the tubes? regards
nastor
nastor
17.232
hace 6 años
hace 6 años
Hello For the installation you only have to leave the bases (hooking the ends) in the frame and give direct tension of the line to know: regards
Discohe
hace 6 años
Ok, it was clear and thanks to all who answered ...
MPM
MPM
MPM
6
hace 6 años
hace 6 años
A few days ago buy some Phillips that can be powered with the reactance of standard fluorecent. At the tip of the tube (t8) they have a primer that you must replace with the old one. This way you leave everything as it was and the only thing to do is change the tube and put in new primer (that comes with the tube). regards
