Household Electricity
12v power supply connection for led reflector
fabi1965
fabi1965
1.293
hace 6 años
hace 6 años
Good evening I would like to make an inquiry I was from a customer who has a fuel station and wanted to replace a few lamps of alogenas for some led reflectors so that it dismounts everything that this equpo takes and install the reflector of led with its box explosion that is demanded for these classes of service stations and inside that box connect the power supply of the led and by mistake connect it to the reverse when you lift the heat jump as it was night I have to go tomorrow morning my query is that possibility there is this source is burned because looking for the image of this power supply I see that on the side that says ACL (brown), ACN (blue) and the symbol of earth to earth it would connect to the 220 volt line. I connected it to the led reflector and the other part that says V + (red) and V- (black) that would connect the LED reflector connect the 220 volt line here I leave an image of the power supply of the led from now on many thanks to the answers you can give me and GREETINGS
fabi1965
fabi1965
1.293
hace 6 años
no samuel was done at night and I was installed with the low heat, tomorrow I have to go and try
samuel2015
hace 6 años
best friend that you check it before connecting it again and see what the damage is if you tried it before you damaged it more
fabi1965
fabi1965
1.293
hace 6 años
hello good night you had reason NASTOR (greetings) burned so I tried with another and I worked the burned the disarm but it can not be repaired because it has a resin that covers all the components so I will have to buy one to give back to the client since I have to put 3 more
samuel2015
hace 6 años
what a good friend
nastor
nastor
17.232
hace 6 años
hace 6 años
Hello Burned that source almost sure ; just be very lucky and only the limiting fuse that many have burned. Try connecting it properly, and not if it works you can disarm it and see what it looks inside. regards
fabi1965
fabi1965
1.293
hace 6 años
Ok thanks for the prompt answers and I do not close the question so I comment tomorrow that happens GREETINGS
