Household Electricity
Standardized channel cable.
Heku
Heku
132
hace 6 años
hace 6 años
Good . According to the AEA that minimum heights can be installed cablecanal in an address or trade? Either to put a mouth of shots or points, junction of shots at a distance of 2mts, or, union of inspection boxes on the wall.
agustinp
agustinp
2.247
hace 6 años
the shots, points and boxes is the same as the installation, 50cm, 1.30mts, 2.20mts ... does not change
that's why I do not think the cablecanal can not be put at this level
elektomaq
elektomaq
62.202
hace 6 años
hace 6 años
Hello According to AEA 90364.7.771- item 12-3 SAVED, HIDDEN AND VISUAL CHANNELS AND ACCESSORIES 1) General: In particular, the edge of the box closest to frames, floors and ceilings shall be located not more than 0.25 m from the outer edge of each frame of openings placed on site, at no more than 0,30 m of ceilings or ceilings and not more than 0,20 m of floors. Diagonal lines are not allowed. [/Color] this rule includes the cablecanales as canalization admitted to the view there are no minimum or maximum heights for the cablecanal lines, in fact there are cablecanales of floor or type zocalo (it simulates a base). if there are regulatory distances for boxes as indicated in the paragraph quoted regards
nastor
nastor
17.232
hace 6 años
hace 6 años
Hello An installation with cablecanal is not a reliable installation, so it would be wrong to limit or regulate something that already has security holes; in any case, it should respect the recommended distances for sockets and points in built-in boxes. To put it in a vulgar way, trying to regulate cablecanal is like getting an ordinance forbidding dogs to bite, that is to say, it has no meaning. Greetings to all
elektomaq
elektomaq
62.202
hace 6 años
the cablecanal is a type of approved and regulated canalization, which should not be changed system. For example, you can not reread with cablecanal to a recessed box, (something that is much seen)
nastor
nastor
17.232
hace 6 años
True, but approved and regulated does not mean insurance, at least in this case. The worst recessed installation is better than one made with cablecanal, that is why it seems to me that it is not logical to regulate its use.
Heku
Heku
132
hace 6 años
hace 6 años
Good Nastor and Elektomaq. Punctually my doubt was by axis: External socket about 40 cm from the finished floor with a cablecanal that rises vertically towards the ceiling and connects to an outside inspection box as well. That distance was my doubt. And the other is, from that same outlet I would install with another cable channel in horizontal form another external outlet. In some cases I have used schneider brand cable channel. These meet one standard and the same as other brands. Is one of the characteristics of this standard that it is fire retardant?
nastor
nastor
17.232
hace 6 años
Hi.
There are no problems as to the height of the shots, only common sense; today they are used to 40/45 cm of the floor, 20 years ago they were used to 25 cm. In the placement of cablecanal sends the aesthetics, and security is given by the capacity of the electric, so it does not matter if you place it diagonally or in a circle, the problem does not happen there as far as the confidence in that system.
Put it as you want is correct, remember to use boxes of good capacity where you make splices, and the cablecanal Schneider (type 301) is very good and good capacity.
nastor
nastor
17.232
hace 6 años
A good system is to stick the cablecanal with its adhesive and then screw every 45 cm.
If it is sold in a streamlined market (IRAM seal) it is supposed to be regulatory, but I do not know the approval certificates that these cablecanal have.
I repeat once again, regulations are made for those who are always on the verge of evading them, you can evaluate how sure you do your job, that is in your hands.
regards
Heku
Heku
132
hace 6 años
Okay. Thanks Nastor. regards
