Nastor
I said: the right way at my discretion. I did not say it wrong the other way. Both your opinion and mine are personal opinions but the safety does not go hand in hand with saving material ... I would not fill a tray of splices everywhere and described how I would avoid it (PERSONAL OPINION) I do not even say be the best option or be the most appropriate ..... each after choosing what suits you best
------ Nastor response box ----- or ----- Agustin said: Speaking always on tray, then, which one would be correct? ".
------ Nastor answers to Agustin: Correct is not the word, but it is a personal choice; would choose
------------ elektomaq, you do not have to be angry, nowhere do I make references to your sayings.
regards
Hi, what I was looking for was to know if any of the two is incorrect, but as they tell me the two can be well then. I prefer to waste neutral but to have a whole cable since you have to take into account that each joint can fail and lead to short or leaks, but if it is in a tray it is a quilombo. regards
None of the options are expressly forbidden or not allowed by the regulation but to do it as you proposed, every place where a cable opens and splices you have to place box and cable glands. In the long run not to waste wastes boxes and cable glands and you will end up spending more money than placing a few meters more cable
So the waste of material is always because you can not leave the cables open and unprotected
The option that I propose you gain time. You simplify the work and clarify the circuit. (imagine a future repair goes someone has to be guessing and opening a lot of boxes), will be more esthetic with a single box that in itself is MANDATORY since to go down to the key you have to change system (from tray to pipe ) and there whether or by regulation goes the box. So the safest thing is that it is also cheaper than putting boxes everywhere and you will also gain time
regards
