Household Electricity
connect led tubes
Ricardo Luis Gagliardi
hace 6 años
hace 6 años
How to connect a led tube be the brand that is or if there are differences, or other technology inside the led tubes, thanks for reply, greetings. (Where I find the answer?
Alexis Navarro
hace 6 años
hace 6 años
Best regards, friend Ricardo, there is a great variety of led tubes depending on the brand and manufacturer, these in their great variety there are some that can be connected directly to the electrical network, either to 220VAC or 120VAC, you just have to acquire the connection sockets that require the led tube according to their pins, either the T8 or T5 as they are known here in Colombia, there are also those that have transformer equally need of the sockets to be able to install them, when acquiring them you must take into account if they are of direct connection to the 220 or 120VAC or if they require transformer, this information t is supplied by t sell tubes. regards
hace 6 años
The most fashionable blondes and considered good are PHILIPS and OSRAM, HOW TO CONNECT AND OTHERS, HOW CAN I ADJUTE
Alexis Navarro
hace 6 años
Best regards friend Ricardo, here I show different ways to install a led tube, you must take into account according to your brand what type of pins you use as well as your connection sockets and take into account sis on direct connection to the electrical network, quantity that you want to install will depend on the area to be illuminated, the connection of two at least parallel and with a single switch that supports the amperage of both.
Alexis Navarro
hace 6 años
In the first drawing, as you know the phase is interrupted and the neutral comes directly to the led tube, in the second it is the same, always interrupting the phase, the third scheme is identical to the second only with a smaller tube, but the connection it will always be the same in all cases. regards
hace 6 años
hace 6 años
Tyodo correct no question, I have Alexis Navarro the solution.
