It is a good variable regulator Companion Victor, I personally try not to use analog sources because of the limitations they present (excessive heat, a lot of consumption, low stability) I prefer DC to DC conversion modules with included PFCs (super-stable, wide range of input, fixed output and higher output current), it is clear that Mario will have to discern between quality - cost - efficiency, and notify us of favorable results; comrade Víctor, I congratulate you for your wide experience, quick and concrete answers, Regards.
Hello fellow mouseelect63, as you say you do just to comment, I think you really do not know the sources, their families and their new processes, depending on which one you use, the current is no longer limited to delivery, and rather it can be raised or amplify by so mentioning it (for example in the new portable welders, portable starters, etc.), Greetings mate.
