hola, tengo una duda acerca de sustituir un mosfet. quisiera consejo de algún colega. es el k4097.
o 2sk4097 .
adjunto la dirección con el pdf de las especificaciones técnicas.
Type | Code | Pol N | Struct MOSFET | Pd 35W | Vds 500V | Vgs | Vgs(th) | Vgs(off) | Id 9.5A | Tj | Qg 30nC | Tr | Cd | Rds 0.5Ω | Caps TO220F |
2SK3505 | N | MOSFET | 60 | 500 | 30 | 14 | 150 | 16 | 160 | 0.35 | TO‑220F | ||||
2SK3505‑01MR | N | MOSFET | 80 | 500 | 30 | 16 | 150 | 16 | 160 | 0.46 | TO220F | ||||
2SK4097LS | N | MOSFET | 35 | 500 | 30 | 9.5 | 150 | 30 | 44 | 150 | 0.5 | TO220FI | |||
11N50 | N | MOSFET | 195 | 500 | 30 | 11 | 150 | 70 | 185 | 0.48 | TO‑220 TO‑220F TO‑220F1 TO‑220F2 TO‑262 | ||||
12N50 | N | MOSFET | 195 | 500 | 30 | 12 | 150 | 54 | 198 | 0.42 | TO‑220 TO‑220F TO‑220F1 TO‑220F2 TO‑263 | ||||
13N50 | N | MOSFET | 168 | 500 | 30 | 13 | 150 | 140 | 245 | 0.42 | TO‑220 TO‑220F TO‑220F1 | ||||
13N50F | N | MOSFET | 48 | 500 | 30 | 13 | 150 | 100 | 200 | 0.48 | TO220F | ||||
13N50MF | N | MOSFET | 35 | 500 | 30 | 4 | 13 | 150 | 14 | 27 | 202 | 0.48 | TO220F | ||
15N50 | N | MOSFET | 170 | 500 | 30 | 15 | 150 | 150 | 250 | 0.26 | TO‑220F2 | ||||
15N60 | N | MOSFET | 312 | 600 | 30 | 15 | 150 | 200 | 270 | 0.5 | TO‑247 TO‑3P TO‑220F1 | ||||
15N65 | N | MOSFET | 312 | 650 | 30 | 15 | 150 | 125 | 295 | 0.5 | TO‑247 TO‑220F TO‑220F2 | ||||
16N50 | N | MOSFET | 62 | 500 | 30 | 16 | 150 | 150 | 235 | 0.31 | TO‑220F2 TO‑220F1 | ||||
16N50F | N | MOSFET | 38.5 | 500 | 30 | 16 | 150 | 170 | 350 | 0.38 | TO220F | ||||
18N50 | N | MOSFET | 277 | 500 | 30 | 18 | 150 | 165 | 330 | 0.24 | TO‑3P TO‑263 TO‑220 TO‑230 TO‑220F1 TO‑220F2 | ||||
AOTF11C60 | N | MOSFET | 50 | 600 | 30 | 5 | 11 | 150 | 50 | 84 | 0.44 | TO‑220F | |||
AOTF11S60 | N | MOSFET | 38 | 600 | 30 | 4.1 | 11 | 150 | 20 | 37.3 | 0.399 | TO‑220F | |||
AOTF11S65 | N | MOSFET | 39 | 650 | 30 | 4 | 11 | 150 | 20 | 42 | 0.399 | TO‑220F | |||
AOTF11S65L | N | MOSFET | 39 | 650 | 30 | 4 | 11 | 150 | 20 | 42 | 0.399 | TO220F | |||
AOTF12T50P | N | MOSFET | 43 | 500 | 30 | 5 | 12 | 150 | 54 | 63 | 0.5 | TO‑220F | |||
AOTF15S65 | N | MOSFET | 50 | 650 | 30 | 4 | 15 | 150 | 24 | 58 | 0.29 | TO‑220F | |||
AOTF18N65L | N | MOSFET | 50 | 650 | 30 | 4.5 | 18 | 150 | 83 | 271 | 0.39 | TO220F | |||
AOTF20C60 | N | MOSFET | 50 | 600 | 30 | 5 | 20 | 150 | 76 | 145 | 0.25 | TO‑220F | |||
AOTF20C60P | N | MOSFET | 50 | 600 | 30 | 5 | 20 | 150 | 599 | 140 | 0.25 | TO220F | |||
AOTF20S60 | N | MOSFET | 50 | 600 | 30 | 20 | 150 | 32 | 68 | 0.199 | TO‑220F | ||||
AOTF20S60L | N | MOSFET | 37.8 | 600 | 30 | 4.1 | 20 | 150 | 32 | 68 | 0.199 | TO220F | |||
AOTF25S65 | N | MOSFET | 50 | 650 | 30 | 4 | 25 | 150 | 26.4 | 30 | 87 | 0.19 | TO‑220F | ||
AOTF25S65L | N | MOSFET | 40 | 650 | 30 | 4 | 25 | 150 | 26.4 | 30 | 87 | 0.19 | TO‑220F | ||
AOTF27S60 | N | MOSFET | 50 | 600 | 30 | 27 | 150 | 33 | 80 | 0.16 | TO‑220F | ||||
AOTF29S50 | N | MOSFET | 50 | 500 | 30 | 3.9 | 29 | 150 | 39 | 88 | 0.15 | TO‑220F | |||
AOTF29S50L | N | MOSFET | 37.9 | 500 | 30 | 3.9 | 29 | 150 | 26.6 | 39 | 88 | 0.15 | TO220F | ||
AP16N50I | N | MOSFET | 52 | 500 | 20 | 4 | 16 | 50 | 630 | 0.4 | TO220F | ||||
AP50WN270I | N | MOSFET | 41.6 | 500 | 30 | 4 | 20 | 150 | 53 | 140 | 0.27 | TO220F | |||
AP50WN270IN | N | MOSFET | 41.6 | 500 | 30 | 4 | 20 | 150 | 53 | 140 | 0.27 | TO220F‑NL | |||
AP65SL099DI | N | MOSFET | 41.6 | 650 | 20 | 5 | 38 | 150 | 39 | 120 | 0.099 | TO220F | |||
AP65WN470I | N | MOSFET | 41.6 | 650 | 30 | 4 | 14 | 150 | 57 | 120 | 0.47 | TO220F | |||
APQ13SN50AF | N | MOSFET | 48 | 500 | 30 | 4 | 13 | 150 | 100 | 180 | 0.48 | TO‑220F | |||
BRF13N50 | N | MOSFET | 48 | 500 | 30 | 13 | 150 | 100 | 180 | 0.48 | TO220FL | ||||
BRF15N65 | N | MOSFET | 73.5 | 650 | 30 | 15 | 150 | 125 | 295 | 0.44 | TO220FL | ||||
BRF20N50 | N | MOSFET | 38.5 | 500 | 30 | 20 | 150 | 120 | 350 | 0.26 | TO220FL | ||||
BRF20N60 | N | MOSFET | 208 | 600 | 30 | 20 | 150 | 140 | 1280 | 0.19 | TO220FL | ||||
CEF18N5 | N | MOSFET | 74 | 500 | 30 | 5 | 18 | 150 | 28 | 305 | 0.27 | TO‑220F | |||
CM13N50F | N | MOSFET | 55 | 500 | 30 | 13 | 150 | 0.5 | TO220FH | ||||||
CM18N50F | N | MOSFET | 65 | 500 | 30 | 18 | 150 | 0.45 | TO220FH | ||||||
CM20N50F | N | MOSFET | 80 | 500 | 30 | 20 | 150 | 0.3 | TO220FH | ||||||
CM20N60F | N | MOSFET | 80 | 600 | 30 | 20 | 150 | 0.45 | TO220FH | ||||||
CS13N50FA9D | N | MOSFET | 60 | 500 | 30 | 13 | 150 | 16 | 160 | 0.5 | TO220F | ||||
CS13N50FA9R | N | MOSFET | 42 | 500 | 30 | 13 | 150 | 21 | 195 | 0.5 | TO220F | ||||
CS15N50FA9R | N | MOSFET | 70 | 500 | 30 | 15 | 150 | 30 | 235 | 0.4 | TO220F | ||||
CS16N60FA9H | N | MOSFET | 70 | 600 | 30 | 16 | 150 | 52 | 18.5 | 0.5 | TO220F | ||||
F11F60CPM | N | MOSFET | 50 | 600 | 30 | 3.5 | 11 | 150 | 22 | 25 | 60 | 0.3 | TO‑220F | ||
FCPF150N65FL1 | N | MOSFET | 39 | 650 | 20 | 5 | 24 | 150 | 15 | 91 | 0.15 | TO‑220F | |||
FCPF220N80 | N | MOSFET | 44 | 800 | 20 | 4.5 | 23 | 150 | 19 | 100 | 0.22 | TO‑220F | |||
FCPF290N80 | N | MOSFET | 40 | 800 | 20 | 4.5 | 17 | 150 | 14 | 75 | 0.245 | TO‑220F | |||
FCPF400N80ZCN | N | MOSFET | 36 | 800 | 20 | 4.5 | 14 | 150 | 0.4 | TO220F | |||||
FDPF15N65YDTU | N | MOSFET | 38.5 | 650 | 30 | 5 | 15 | 150 | 125 | 295 | 0.44 | TO‑220F | |||
GPT13N50D | N | MOSFET | 47 | 500 | 30 | 13 | 150 | 59 | 180 | 0.49 | TO220F | ||||
IPA80R310CE | 8R310CE | N | MOSFET | 35 | 800 | 20 | 3.9 | 16.7 | 150 | 15 | 90 | 0.31 | TO‑220F | ||
LSDN65R380HT | N | MOSFET | 90 | 650 | 30 | 4.5 | 11 | 150 | 14.7 | 32 | 36.1 | 0.38 | TO‑220F | ||
MDF13N50BTH | N | MOSFET | 41 | 500 | 30 | 4 | 13 | 150 | 47 | 174 | 0.5 | TO‑220F | |||
MDF13N50GTH | N | MOSFET | 42 | 500 | 30 | 5 | 13 | 150 | 54 | 173 | 0.5 | TO‑220F | |||
MDF13N65B | N | MOSFET | 36.7 | 650 | 30 | 4 | 14 | 150 | 81 | 243 | 0.46 | TO‑220F | |||
MDF13N65BTH | N | MOSFET | 36.7 | 650 | 30 | 4 | 14 | 150 | 81 | 243 | 0.46 | TO‑220F | |||
MDF15N60GTH | N | MOSFET | 36.7 | 600 | 30 | 5 | 15 | 150 | 86 | 258 | 0.4 | TO‑220F | |||
MDF16N50GTH | N | MOSFET | 49.4 | 500 | 30 | 5 | 16 | 150 | 88.5 | 226 | 0.35 | TO‑220F | |||
MDF18N50BTH | N | MOSFET | 37 | 500 | 30 | 4 | 18 | 150 | 82 | 307 | 0.27 | TO‑220F | |||
MSF13N50 | N | MOSFET | 48 | 500 | 30 | 4 | 13 | 150 | 120 | 180 | 0.48 | TO‑220F | |||
MSF16N50 | N | MOSFET | 205 | 500 | 30 | 5 | 16 | 150 | 180 | 330 | 0.38 | TO‑220F | |||
MSF18N50 | N | MOSFET | 235 | 500 | 30 | 5 | 18 | 150 | 190 | 400 | 0.32 | TO‑220F | |||
MSF20N50 | N | MOSFET | 40 | 500 | 30 | 4 | 20 | 150 | 400 | 400 | 0.26 | TO‑220F | |||
R5011ANX | N | MOSFET | 50 | 500 | 30 | 4.5 | 11 | 150 | 30 | 28 | 400 | 0.38 | TO220FM | ||
R5011FNX | N | MOSFET | 50 | 500 | 30 | 4 | 11 | 150 | 30 | 28 | 580 | 0.4 | TO220FM | ||
R6010ANX | N | MOSFET | 50 | 600 | 30 | 10 | 150 | 25 | 30 | 720 | 0.43 | TO220FM | |||
R6010MNX | N | MOSFET | 56 | 600 | 30 | 5 | 10 | 150 | 20 | 25 | 900 | 0.38 | TO‑220F | ||
R6011KNX | N | MOSFET | 53 | 600 | 20 | 5 | 11 | 150 | 22 | 25 | 630 | 0.39 | TO‑220F | ||
R6511KNX | N | MOSFET | 53 | 650 | 20 | 5 | 11 | 150 | 22 | 20 | 710 | 0.4 | TO‑220F | ||
R6515KNX | N | MOSFET | 60 | 650 | 20 | 5 | 15 | 150 | 27.5 | 35 | 980 | 0.315 | TO‑220F | ||
RJK5014DPP | N | MOSFET | 35 | 500 | 30 | 19 | 150 | 41 | 0.39 | TO‑220FN | |||||
RJK6054DPP‑M0 | N | MOSFET | 35 | 600 | 30 | 16 | 150 | 22 | 175 | 0.475 | TO220FL | ||||
SIF12N60C | N | MOSFET | 225 | 600 | 30 | 12 | 150 | 0.5 | TO‑220 TO‑220FP | ||||||
SIF13N50C | N | MOSFET | 170 | 500 | 30 | 13 | 150 | 0.4 | TO‑220 TO‑220FP | ||||||
SIF18N65C | N | MOSFET | 65 | 650 | 30 | 18 | 150 | 0.37 | TO‑220FP | ||||||
SLF60R380S2 | N | MOSFET | 35 | 600 | 30 | 4 | 11 | 150 | 22 | 29 | 38 | 0.38 | TO220F | ||
SLF65R300S2 | N | MOSFET | 35.7 | 650 | 30 | 4 | 15 | 150 | 24 | 37 | 45 | 0.31 | TO220F | ||
SLF65R420S2 | N | MOSFET | 35 | 650 | 30 | 4 | 11 | 150 | 23 | 35 | 37 | 0.4 | TO220F | ||
SLF70R420S2 | N | MOSFET | 130 | 700 | 30 | 4 | 11 | 150 | 24 | 37 | 37 | 0.42 | TO220F | ||
SMIRF13N50T2TL | N | MOSFET | 60 | 500 | 30 | 4 | 13 | 150 | 30 | 50 | 190 | 0.48 | TO220F | ||
SRM20N65TF | N | MOSFET | 40 | 650 | 30 | 3.6 | 20 | 150 | 318 | 0.45 | TO‑220F | ||||
SSF18N50F | N | MOSFET | 38 | 500 | 30 | 18 | 150 | 80.3 | 290 | 0.35 | TO220F | ||||
SSF50R140S | N | MOSFET | 35 | 500 | 30 | 4.5 | 24 | 150 | 30 | 11 | 370 | 0.14 | TO220F | ||
SSF80R240S | N | MOSFET | 35 | 800 | 30 | 4.5 | 18.4 | 150 | 27.5 | 21 | 380 | 0.26 | TO220F | ||
STF12N50M2 | 12N50M2 | N | MOSFET | 85 | 500 | 25 | 4 | 10 | 150 | 15 | 10.5 | 33 | 0.38 | TO‑220FP | |
STF13N80K5 | 13N80K5 | N | MOSFET | 35 | 800 | 30 | 5 | 12 | 150 | 29 | 16 | 50 | 0.45 | TO‑220FP | |
STP11NM60FDFP | P11NM60FDFP | N | MOSFET | 35 | 600 | 30 | 5 | 11 | 150 | 28 | 16 | 350 | 0.45 | TO‑220FP | |
STP11NM60FP | P11NM60FP | N | MOSFET | 35 | 600 | 30 | 5 | 11 | 150 | 30 | 20 | 230 | 0.45 | TO‑220FP | |
STP12NM50FP | P12NM50FP | N | MOSFET | 35 | 500 | 30 | 5 | 12 | 150 | 28 | 10 | 250 | 0.35 | TO‑220FP | |
TK12A50W | N | MOSFET | 35 | 500 | 30 | 3.7 | 11.5 | 150 | 25 | 23 | 23 | 0.3 | TO‑220F | ||
TK12A80W | N | MOSFET | 45 | 800 | 20 | 4 | 11.5 | 150 | 23 | 40 | 29 | 0.45 | TO‑220F | ||
TK13A60W | N | MOSFET | 50 | 600 | 30 | 4 | 13 | 150 | 0.43 | TO‑220F | |||||
TK290A60Y | N | MOSFET | 35 | 600 | 30 | 4 | 11.5 | 150 | 25 | 25 | 26 | 0.29 | TO‑220F | ||
TK290A65Y | N | MOSFET | 35 | 650 | 30 | 4 | 11.5 | 150 | 25 | 25 | 26 | 0.29 | TO‑220F | ||
UF450 | N | MOSFET | 215 | 500 | 20 | 14 | 150 | 47 | 720 | 0.31 | TO‑3P TO‑247 TO‑220F1 TO‑220F2 TO‑230 | ||||
UK3568 | N | MOSFET | 40 | 500 | 30 | 12 | 150 | 22 | 180 | 0.4 | TO‑220F TO‑220F1 |
Encontrado en total 102
