Electronics and Circuit Design
I have to control the coil of a water pump start contactor
nestor raul
assemble a timer with 555 coupled with a MOC3021 to a BT138 600E, can I load the coil of a 220V contactor? Or is it better to use some power transistor?
pato
pato
16.451
In principle, not if the coil is powered by mains voltage, it would be a known circuit, as long as you do not mix in the triac features, the one mentioned is correct and the contactor must be for mains voltage. if you have doubts make a sketch and subilo
nestor raul
Ok, very grateful.
Hi. If you are going to directly control the coil with the triac you should place a snubber net to protect it from a strong inductive load such as the coil. This is nothing more than a resistor and a series capacitor (1K and 10 nF x 400V) placed between A1 and A2 of the triac. I leave you a link to see how to do it. regards http://www.forosdeelectronica.com/f23/triac-optoacoplado-lamparas-led-126031/
nestor raul
Thank you very much for the circuit.
I have it armed but I was missing the snubber network.
I already add it.
