Electronics and Circuit Design
Alternatives to 7812 and 7912
J. E. T
J. E. T
810
Hello good I have been looking for a couple of 7812 and 7512 for 3 days to manufacture a source but for more than I look for it I don't help them there are only 7905 and 7805 Already disassemble 5 PC sources and do not carry them ask in local electronics and are sold out So I want to know what their similar ones are based on other brands or types and since the PC power sources carry voltage rectifiers after the winding that gives the voltage but this does not help me I hope and give me a hand what can I do to replace these 2 Thanks in advance I update: While looking for the possible substitutes proposed I found the source faith an old hp work station that had just what I needed thanks everyone for your help Annex photo of the unattainable
Enriquesoftware
There is no 12V regulator in stores?
J. E. T
J. E. T
810
Unfortunately, I live very far from where there are electronics, there are only 2 around here and everything is on request
Enriquesoftware
Excellent that good that you got in your disuse .................. to see if you can help me in my question of a panasonic TV that the TV signal goes away and in Video looks monochromatic
Enriquesoftware
KA7812 KA7912 L7812 L7912 LM7812 LM7912 LM2940CT-12 12V LDO Regulator 1 Amp, 78L12, 79L12
J. E. T
J. E. T
810
Thank you that will be useful
Jorge GG
Jorge GG
523
At 7805 put a 7 volt zener diode between the ground leg and the negative of the source and became a 12 volt regulator, 5 + 7 = 12. You can do it with any linear regulator.
As Albert Einstein said it all depends on the benchmark.
