Hello, what each source delivers is independent of what each cooler consumes, on the other hand you have no choice but to put them in parallel since they are 12V the same as the source. What can be put is a fusistor in the event that someone gets heavy over time and begins to heat, to protect the source.
Thank you very much, could you promptly tell me which one I should use for each case? Greetings.
Thanks for your response, I am new to this and I try to learn from the forums and what I find on the Internet, my perception regarding this issue was that if the difference between the Amperes that gave the source and the sum of the amperes of each cooler was large, what could happen was that each cooler receives much more current than it needs causing it to overheat or have negative effects.
According to your comment, you are telling me that the problem is that the source would be working at maximum capacity but that the above is true. Greetings and thanks
