Electronics and Circuit Design
Home investor
Gabriel Electronics
Hello, good night, I hope you don't close the question. I built an inverter in the 12v to 220v school. The problem is that I want to connect it to a 12x80 car battery, when it is charged it has 13.6V and my investor starts to throw 280v at its exit, some circuit with 7812 that starts 12.5A up, with any power transistor?
Hi. What power are you taking from the secondary of the inverter, that is, in 220V? If you need something that amplifies the voltage I leave you a link of up to 15 amps. Regards http://jorgefloresvergaray.blogspot.com/2009/10/aumentar-la-salida-de-los-78xx.html
Gabriel Electronics
Very good the inverter is 150w
Jean Vilain Vilain
And if you put a 12v regulator in the current input? I don't tell myself luck
Gabriel Electronics
But the problem is that the regulator withstands between 1A or 1.5A and I presume a current of 12.5A at the maximum, which would burn or drop the voltage
yariel
yariel
182
Friend measures the inverter with load. In a vacuum it measures that tendency but it is peak-peak, not an effective value. Put some considerable burden on it and you will see how it drops to a reasonable level. It is possible to regulate what is a little more complex. Tell me of the results to continue helping. Regards
Gabriel Electronics
Very little 3v voltage drops at the output will not be due to the square wave that increases the voltage so much?
