Electronics and Circuit Design
circuit that indicates me full charge in 12v battery.
El_Loko
I need a circuit that tells me that the load is complete, If it is possible that it does not take up much space since it is to be installed in a small space.
Salvador perez maximo
Hello, good afternoon, how many amps and technology is the battery?
El_Loko
Hello, they are laptop batteries put in series for 12 volts, each battery is 3v and in series it is a total of 4, plus four more to give it more power. The amperage I don't know how much it will be.
ndarz
ndarz
826
Hello friend, I leave you a circuit, the potentiometer is to regulate the integrated supply voltage, you can replace it with resistance. R4 is critical, changing its value will be the voltage limit to which the last LED will turn on (the green one), that value of 6K9 is what you need, you have to do it with 2 or 3 resistors in series, you also have to try With what value fits you better, the green would have to turn on between 16.2 V and 16.5 V for 4 series batteries of that type. Remember that LiOn batteries should not be charged with common chargers.
El_Loko
thank you i will see if i can do it
tonyelloco
there are several circuits with transducers let us see if I find them here to put them aver colleague I just found this I hope you serve without telling me and I will try to put another https://unicrom.com/monitor-de-carga-de-bateria-con-lm3914/ https://unicrom.com/monitor-de-carga-de-bateria-para-automovil/
El_Loko
Thank you for your support friend, my email is asielper@ctehabana.une.cu, and thanks again.
tonyelloco
see colleague I just found this I hope you serve without telling me and I will try to put another
