Electronics and Circuit Design
battery replacement
zeustronico
friends I have a small device that works with a battery of 200 mAh, with a voltage of 3.7 v, l my question is if I can replace it with a battery of 850 mAh, with the same voltage, which could happen. Thank you for your answers
pato
pato
16.451
sitenes place makes the replacement without any problem
Frank Phorlakis
Good night, friend regarding your question, what you have to respect is what type of technology was used, that is, what type of bacteria, for example: Nicd, NiMh, Lipo, Lithium, etc., why this? If your equipment has a NiCd rechargeable battery and you replace it with a Lipo, be assured that Lithium bacteria would come on fire because the batteries have specific charging methods that prevent fires ... Now with respect to the capacity of current, you can place without any problem batteries of the same type with current capacity higher than the Original .... What happens with this: If you put a battery with greater current capacity, only the equipment will remain longer running, it's like you put a larger water tank in your home ... Let's make a small example: If your equipment has a consumption of 500 mAh and you have a 2000 mAh battery, it will work 4 hours, but if now change the battery capacity to 3000 mAh, the equipment will work 6 hours .....
