Electronics and Circuit Design
Switching source
Gregorio829
Hello friends. I have a switched source of 8Amp and 14v. The source delivers 14 volts but when the load is placed the voltage goes to 0v. Which component will be damaged? I already rectified all the welds and still the same.
Joe Black
They have to be filters bro test changing the output ones and if it persists change the ones from further back
Gregorio829
A million thanks to the 2. At the exit of the source has 3 filters of 2200uf and 25v one marked 4.65uf, the other 200uf and the third 2400uf, change them all and ready ... it works perfect. GRATEFUL..
bryanyami
as indicated by the partner, verify that the condensers understand in good condition if you do not have to change them if the problem persists verify the fat capacitor of the input. oscillation or the reference ic located near the optocoupler
