Electronics and Circuit Design
ic smd control and oscillation of mosfet in switched source
Canario2016
Hello Could someone tell me what is the commercial name of this mosfet control and oscillation ic in 1 switching source of 12v 2a? It has a kind of code 9 superscript P, but I'm not sure. If someone indicated me the real name or purchase link, I would appreciate it because I must replace it. Regards!
JMBL
JMBL
40
I think you can use this LD7535, look at the features and check that the pins match. (Power, output for the MosFet, etc.). And then a link where you can buy it: https://es.aliexpress.com/store/product/5-unids-LD7535ABL-SOT23-6-LD7535-Sot-LD7535A-SMD-env-o-libre/1395137_32842014626.html?spm=a219c.search0104.3.50. af2c30ffdp5dzG & ws_ab_test = searchweb0_0% 2Csearchweb201602_2_10152_10065_10151_5711320_10344_10068_10342_10547_10343_10340_10341_10548_10698_10697_10696_10084_5722520_10083_10618_10307_10301_10303_5711220_10059_5722620_5722920_10184_308_5722720_5722820_100031_10103_441_10624_10623_10622_10621_10620% 2Csearchweb201603_19% 2CppcSwitch_4 & algo_expid = 38b1df7c-042d-46CE-b8e8-615f84a9de59-7 & algo_pvid = 38b1df7c-042d-46CE-b8e8-615f84a9de59 & priceBeautifyAB = 0 Regards.
Canario2016
Thanks, JMBL
