Electronics and Circuit Design
Transistor npn c3866 is equivalent to c4533
nocblue
Friends, I am very sorry to look at the specifications of the components, the truth is that they have so much information that I don't know what to look at, could they help me? I need to know if these npn transistors are equivalent c3866 = c4533
nocblue
I thank you if you can explain to me that I should look in the datasheet to know if they are compatible, anyway I need you to confirm me, as I do not understand very well what is to be compared I am afraid to get to err and do some damage to the circuit ... Beforehand thank you very much
ricbevi
ricbevi
17.055
It all depends on the circuit where you are working, in principle it has parameters such as the collector voltage and the current that are different. The C3866 could work safely replacing the C4533 but conversely, no. Regards. Ric. -------------------------------------------------- -------------------------------------------------- -------------------------------------------------- --------------------- It depends on the electrical circuit, they are the parameters that you should set. Ex: To replace a transistor in an RF amplifier stage it cannot be set only in the type of polarity and transistor that is how it could be replaced in a simple low frequency switching stage. You have to look at parameters such as the maximum power supported, the current, the CE voltage, the FT, the HFE, etc. You can put in any search engine the phrase Replacement 2Nxxx and it will surely bring you useful information. It is generally sought that the important parameters such as those described above are similar or greater than those of the original transistor but if they are different than these do not go too far. In the power Mosfet the Rds-on parameter is important apart from the supported TensionDS, the maximum current. There are pages on the Web that show some transistor substitutes but with the great variety of them there is impossible that one contains them all. Ex: http://www.reparacionlcd.com/transtandar.php https://www.electronica-pt.com/db/componentes.php?ref=2SC3866 https://alltransistors.com/es/ Regards. Ric.
nocblue
I thank you very much ricbevi, I would like to ask you something, is that it has always been difficult for me to look for transistor substitutes, in which I should look at the datasheet to know if it serves as a replacement ???? Do you know any way to identify which are the equivalent replacements of a transistor ..... ???, is that as in this case they are different, but still it works and I don't know how to know if it serves me or not?
nocblue
thank you very much for your help
