Electronics and Circuit Design
48v 20A power supply
doom
doom
14
hace 6 años
hace 6 años
Does anyone have any diagram or circuit of a 48v 20A power source or a 48v voltage regulator?
JOSE MIGUEL SIRGO PASCUAL
hace 6 años
hace 6 años
I have an adjustable regulator of my invention that suits you for what you want to do. you just have to add a suitable amperage transformer, a diode bridge that supports that amperage and a capacitor of at least 20,000 microfarads. You have to refrigerate the mosfet transistor with a good metal fin. It would be advisable to use two mosfet transistors in parallel to ensure that they do not exceed the recommended maximum wattage when working on low voltage outputs that is when more voltage is in the transistor.
sergiouasd
sergiouasd
3.527
hace 6 años
good .
what you burn if you try to get 20A, it burns with less.
you should look for a PWM regulator circuit for those magnitude of current.
hace 6 años
I do not think so. This transistor can withstand 64 amps at 100 degrees and can dissipate 230 watts maximum.
If we use 2 in parallel as indicated, there will be no problem in the case of lower voltages.
Keep in mind that the applicant requests to regulate 48 volts and in that case the voltage drop in the transistor is only 2 volts that multiplied by the 20 amps that he wants to take out are only 40 watts of dissipated power.
50v-48v = 2v.
Of course, it is essential to place a heatsink as directed.
neybero
neybero
46
hace 6 años
A query.
What function does the resistance of 0.04 ohm / 15W in the negative. What happens if I eliminate this resistance?
neybero
neybero
46
hace 6 años
hace 6 años
A query. What function does the resistance of 0.04 ohm / 15W in the negative. What happens if I eliminate this resistance?
sergiouasd
sergiouasd
3.527
hace 6 años
good .
that is a shunt resistor, converts the current into voltage and polarizes the DB137, so that when the 0.7V of the drop in this resistance is reached, the transistor is activated, at that moment it takes the mosfet gate to GB, which you must pay it and avoid the current conduction, in reality it is not possible to turn off only the output current and the voltage in the R of 0.4 ohm are limited, it is close to 0.7V, but it does not fully activate the transistor and therefore the mosfet is not completely turned off.
neybero
neybero
46
hace 6 años
Thank you Sergiouasd for your comment. I'm interested in the circuit since I'm looking for a similar source with high current. Although I understand electronics a bit, it is not so much to get involved in the analysis of some designs since my training is electricity.
I want to incorporate a voltmeter and a perimeter. What I fear of the temperature generated by the resistance with a load at a voltage of 24 and current of 10 Amp. That implies a power of 240W. I don't know if in the local market I would find that resistance resistance. How important is the transistor designed on resistance?
mdav1982
hace 6 años
hace 6 años
Hi good day. I think if the value of the resistance is 0.04 and 10 amp. The power is IxIxr. 10x10x0.04 = 4w. Regards.
hace 6 años
If you put the resistance of the same power that is generated it will happen that it will end up deteriorating soon. Putting more power will not get so hot and welds will not suffer fatigue.
