Electronics and Circuit Design
12v cc regulator
Alekz Gonzalez
hace 6 años
hace 6 años
YOREPARO COMPANIONS SOMEONE WHO KNOWS OF ANY INTEGRATED OR TRANSISTOR TO REGULATE 18VDC 3.3AMP TO 12VDC 3.3AMP? I HAVE TESTED WITH THE LM7812 BUT THOSE INTEGRATED CAN ONLY 800miliamperes. ANY METHOD TO REGULATE REMOVING ALL THE POSSIBLE AMPERAGE OF THE SOURCE?
JOSE MIGUEL SIRGO PASCUAL
hace 6 años
hace 6 años
Use the LM338 which is an adjustable positive linear regulator that supports a maximum of 5 amps. http://www.ti.com/lit/gpn/lm338
Alekz Gonzalez
hace 6 años
My dear Jose Miguel already saw it and I find it interesting, what is not clear to me is how to adjust the regulator, do you have any idea? The instructions on the page are not very clear, which is apparently regulated with a resistance, isn't it? and about the use is more or less this: I have lap top chargers (18v 3.3amp) that I want to use to power 24 "LCD screens (12v 3.0amp) so would the use of the LM338 be appropriate?
hace 6 años
The output voltage is adjusted by a potentiometric trimer of 5k ohms. which appears in the scheme as R2.
He had the scheme somewhat clearer.
ricbevi
ricbevi
17.055
hace 6 años
hace 6 años
It depends on the use you give and the starting voltage to regulate at 12V. There are regulators such as those that suggested to you but its use is not always recommended for certain purposes due to the large heat dissipations they involve. They have the advantage of simplicity of connections and availability in the market but other cons that for some uses are unacceptable. By the way .... what is usually regulated / stabilized is the output voltage (devices of type 7812), not the current, Regards. Ric.
hace 6 años
The consultant clearly says that he wants to go from 18 volts to 12 volts so there will not be much power dissipation.
It will be 6 volts of difference by 3.3 amps gives us 19.8 watts which is more than reasonable.
ricbevi
ricbevi
17.055
hace 6 años
I had not visualized the 18V data, the apologies .... I also insist with my opinion, it all depends on the use, in facilities where the W consumed must be optimized, 20W in the form of heat may be unacceptable or not. Today, voltage regulating modules with high energy efficiency at very low cost are available on the world market (generally and with exceptions) Ex: https: //articulo.mercadolibre.com.ar/MLA-768446361-xl4005-step-down -convertidor-dc-dc-5a-source-08-a-24v-_JM Regards.
Alekz Gonzalez
hace 6 años
Thank you very much to all I stay with the recommendation of Jose Miguel ..
Now, to get to work!
THANK YOU!
ricbevi
ricbevi
17.055
hace 6 años
There are no problems, here we are to propose different solutions if there are any and the participant decides and stays with the last word of what he wants to do since he will have to deal with the consequences like everything in this life .... Luck and good accomplishment of the project. Ric.
